RSide Advanced S. Shifter DIY Install
Old Apr 21, 2004 | 05:02 PM
  #31
<div class='quotetop'>QUOTE (REDZMAN)</div><div class='quotemain'>If your DIY is put up and is missing any of these, you <span style="font-size:24pt;line-height:100%"><u>may</u></span> not get added to the list.</div>
Besides, you guys must be blind, it clearly states the beer of choice in that install.
As for 'breaks in my installs' there usually are, this whole install took about 15 minutes.
Old Apr 21, 2004 | 05:06 PM
  #32
tibwrcsbj's Avatar
c, someone else read the rules REDZMANG, and i was J/K about it sucking. Yeah i saw the visor.........but you didn't say when it was ok to drink......
Oh and the Rside Knob will go on lined up if you use enough elbow grease. at least mine did, of course i tried that w/ the stock knob, and had to strip the threads inside to get it off.
Also, my DIY for making your fingers not hit the cup holder will only work w/ the b&m shifter, even as far back as possible the rside one will still make your fingers hit the cupholder.
Install went great, besides what i mentioned above....leaving work now, got 35 miles of back roads to try it out on..........
THX REDZ :-)
Edit : Have an idea for moving the shifter back further.....don't know if it will be enough though........ :roll:
Old Apr 29, 2004 | 01:50 PM
  #33
AllBlackTibby's Avatar
What's this I keep hearing about the RSide and the cupholder???? Please inform as I Just bought the shifter.
Old Apr 29, 2004 | 01:52 PM
  #34
cdogtibby1's Avatar
when the cupholder is out you will hit your knuckles on it... the shifter is moved up a little bit from OEM position... nothing big though
Old Apr 29, 2004 | 04:45 PM
  #35
you can adjust it though so it doesnt. there are bolts down there you can use to adjust the tightness and such of the cables.
Old Apr 29, 2004 | 05:00 PM
  #36
cdogtibby1's Avatar
whoa... explain that man... i am installing mine this weekend and i will want to tweak with it while its all taken apart man... got any pics... maybe you should do a DIY
