I think it would be a good idea for those who are new if we all posted pix of our maintenance projects. At least identify, in pictures, those components which need to be changed.
K, i just picked this up from the local hyundai dealership. 3000 miles: Change oil and filter, inspect fluids, general inspection 6000 miles: Change oil and filter, Tire rotation, Inspect/top fluids, general inspection 15,000 miles: Change oil and filter, flush oil, check battery, rotate tires, replace air filter, general inspection mini 30,000 miles: Change oil, filter and gasket, flush oil, flush coolant, check battery, rotate tires, general inspection major 30,000 miles: Change oil, filter, and gasket, flush transmission, flush engine, flush cooling system check battery, adjust brakes, replace air filter, rotate tires, general inspection. install a/c disinfectant, flush engine, fuel treatment, clean injectors. Those last 4 are just additives. I think if we could come up with a separate sub-forum for little stuff like this where we won't all be afraid to post just 1 pic and call it a "DIY" it might increase our helpfullness to the hyundai public. Maybe it could be a DIY/maintenance DIY section. just a little nook that someone could look at and decide "Hey, i havn't changed my fuel filter in ages! I'm glad someone was nice enough to put up a DIY!" I'm just saying it sounds like a good idea to me. Anyone could post just a pic and explain how it goes. Like a haynes manual or something. Right now I'd be intimmidated if I weren't doing a full 30,000 mile service as a DIY, but I do mine all within like a month or so, I'd never remember to do a FULL diy. |
lets see, i would like a DIY angel eyes for an RD1, and the a/c and p/s pulleys. and maybe even a white gueage face DIY for an rd1.
i know these will be tuff since this forum is dominated by the little brother rd2s |
<div class='quotetop'>QUOTE (tibby01 @ Sep 29 2005, 08:18 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Anything maintenance-related that you do not know how to do, post it up. Don't post requests for putting leds in the cupholders or anything crazy like that, just maintenance/fixes for things that are bothersome with the tib. They will go in the DIY listing under maintenance, with a reference in the New Users Section as well.
I'll start off with a few that we need, and what I plan to do soon: -Timing belt change -Oil change -Radiator fluid change -Bleeding the brakes</div> |
<div class='quotetop'>QUOTE (J3R0MY @ Mar 3 2007, 08:34 PM) <{POST_SNAPBACK}></div><div class='quotemain'>lets see, i would like a DIY angel eyes for an RD1, and the a/c and p/s pulleys. and maybe even a white gueage face DIY for an rd1.
i know these will be tuff since this forum is dominated by the little brother rd2s</div> theres a diy guide for the angel eyes, even a video done, and im pretty sure it was with a RD1, should be on the forums somewhere and tibby01, a DIY on any of those would be sweet, well besides a oil change lol. but especially bleeding the brakes cause i dont anything about it, and probably have to do it soon |
<div class='quotetop'>QUOTE (J3R0MY @ Mar 3 2007, 06:34 PM) <{POST_SNAPBACK}></div><div class='quotemain'>lets see, i would like a DIY angel eyes for an RD1, and the a/c and p/s pulleys. and maybe even a white gueage face DIY for an rd1.
i know these will be tuff since this forum is dominated by the little brother rd2s</div> Should I slap you around and call you a b**** or warn you? J3ROMY, you need to SEARCH. There is a DIY for angel eyes. Even if it's for RD2's, the method is the same, except it's easier on the RD1. It's a CONCEPT DIY, if you get the idea, you can do it. There is a DIY for ALL OF THE FRIGGIN PULLIES. Guess what? They are the same for both cars, as they are the same motors. THERE IS A DIY FOR GAUGE FACES TOOO! Holy shit man, what's the problem? The gauge face process is the same for either gen, but like one or 2 steps less for the RD1. If you can't figure that out, should you be working on your car at all? |
<div class='quotetop'>QUOTE (Vladimer @ Mar 4 2007, 12:29 AM) <{POST_SNAPBACK}></div><div class='quotemain'>theres a diy guide for the angel eyes, even a video done, and im pretty sure it was with a RD1, should be on the forums somewhere
and tibby01, a DIY on any of those would be sweet, well besides a oil change lol. but especially bleeding the brakes cause i dont anything about it, and probably have to do it soon</div> bleeding the brakes i can do very soon more than likely. |
moved your post to the engine & transmission section madrik.
<div class='quotetop'>QUOTE (tibby01 @ May 9 2007, 06:54 PM) <{POST_SNAPBACK}></div><div class='quotemain'>moved your post to the engine & transmission section madrik.</div>
Got it - thanks |
I searched, but couldn't find a diy for a/c and p/s pulleys?
Also, eibach pro kit lowering springs? Thanks |
1. maintenance requests only.
2. check listing in the sticky of DIY section. in maintenance, you will see two posts on how to change struts. it will be all you need for spring changing. 3. not in diy(redz's post should be copied to it), but easy to find... http://www.rdtiburon.com/index.php?showtop...9&hl=pulley |
| All times are GMT -6. The time now is 09:37 AM. |
