Diy Porting Stock Im
Old May 10, 2008 | 06:48 PM
Jed118's Avatar
Vehicle: Hyundai Pony
DIY Portmatching
Old May 10, 2008 | 07:09 PM
Tibbychick's Avatar
Don't be lazy, copy and paste it.
Old May 10, 2008 | 08:40 PM
UrS0NvS's Avatar
you go chica, break out the whip and control that man.
Old May 10, 2008 | 08:58 PM
very nice writeup, especially if you don't want to lower your eyesight looking for an airram and then spending $800 on top. the stock intake isn't too bad but the interior of it looks like bread.
Old May 10, 2008 | 09:00 PM
supercow's Avatar
nice diy, I'm planning on doing this to my head, intake and tb before I put it all back together. A dremel should do a good job but a die grinder will probably do it quicker.
Old May 12, 2008 | 08:16 PM
AGreen's Avatar
I ported the exhaust on my head and manifold when I did the 1.8 piston swap, but the intake looked like an extremely daunting task. I had it all marked up and ready to port, but there was a good 1/4" of material almost all around to remove!!!! I was afraid I'd run into coolant or oil passages in the head with that much porting, so I lightly smoothed them out and left a semi-smooth polish on it for better air turbulence, and to prevent the fuel from beading up on a highly polished surface. With the high compression pistons and ported head, coupled with the 1.8 cam and CAI I already had, the car's a freakin' screamer. I just need some exhaust now.
There wasn't but about all of a 1/16" of material to move from the exhaust side, so I took full advantage of that!!!
Old May 12, 2008 | 08:58 PM
Caj Darkmoon's Avatar
I did JUST my IM, not the intake runners on the head yet, and noticed a difference in the way the car revs up and the sound. Actually made it sound a lot nicer along with revving more freely.
