what if isnt a perfect circle?
Here´s the size for headlight angel eyes for the RD1, I took these measures from a set I bought from blacktib (that´s his nick I guess)
The inner circle is 5.8 cms and the outer circle is 7.3 cms, I put them in centimeters because that´s the unit we use here, and I´m not used to inches. Hope it´ll help you |
<div class='quotetop'>QUOTE (firebug21 @ Jul 3 2005, 08:35 AM)</div><div class='quotemain'>Well after the holiday I will do a write up for that, Thanks.</div>
its way after the holiday i wanna do this mod and i would like u to finish if u could please. i need to know where to hook the wires to and how to get the vents out smile.gif also how to make a switch to turn them on n off im a newb with leds. and where i can get the leds and accrilyic rods? i know i can get them online would there be a store intown? anybody who knows can help |
Call me a dumbarse, but could this be applied to the headlights as well? Would/have any of you do it?
Yes it can be done for the headlights as well. and some have done it, but most buy them from Chris (blacktibs on the forum) he makes them for us. if you want to try this on your own PM him to find out dimensions.
have you tried putting the cuts in the plastic and THEN bending them? also bending them with the cuts on the inside may provide a more efficient method of refracting the light.
Also, a heated piece of steel wire may provide a better line. |
<div class='quotetop'>QUOTE (tibcr @ Jul 7 2005, 11:53 PM) <{POST_SNAPBACK}></div><div class='quotemain'>The inner circle is 5.8 cms and the outer circle is 7.3 cms</div>
slightly ovaled.. is that the inside diameter or outside? |
Thread resurrection . . . I think this is cool enough, and seldom-enough mentioned to bump.
...plus I had a comment to add: instead of drilling lights, you should be able to superglue the end of the rod to the end of an LED, as long as the rod and LED are both FLAT on the end. Drill AND superglue if you are paranoid about it falling out! |
What possessed you to read a more than 6 year old thread?
I remembered I was not done fixing the broken links in the RD DIY listing sticky thread, and started doing that for a while. It was one of the links I fixed last night/this morning.
| All times are GMT -6. The time now is 07:07 AM. |
