Hyundai Aftermarket
-   DIY (https://www.hyundaiaftermarket.org/forum/diy-46/)
-   -   DIY: The "Big 3" wire upgrade (https://www.hyundaiaftermarket.org/forum/diy-46/diy-big-3-wire-upgrade-25563/)
alabama_boi Aug 29, 2004 02:39 PM
Re: Radiator question/help..
Quick dumb question but is it possible to make the wires less visible??
REDZMAN Aug 29, 2004 03:03 PM
Yeah, you could, but why?
Get some nice colored wire and you are good.
alabama_boi Aug 29, 2004 03:17 PM
Re: e-manage hookup HELP
I just dont care for all the loose wires, but if they were colored it might look better, dunno.
REDZMAN Aug 29, 2004 03:31 PM
Re: Does this video bother anyone else? Deceptacons?
There aren't any loose wires up there. All have been zip tied down.
01tibby Aug 29, 2004 03:46 PM
Re: Veilside Hood & Wing
i know what hes saying. doesnt want to make it look like there are more wires in his engine bay.
alabama_boi Aug 29, 2004 10:10 PM
Re: Fosgate Amp
Yeah, just sorta looks messy in a way to me. I know they're zip tied and all but looks like excessive wires everywhere!
col96fx Aug 29, 2004 11:53 PM
Re: Insomniac Thread
Good job spiceflow. I think I'll do this soon.
I do agree with alabama_boi though (both times tongue.gif ), I'll be trying to hide the wires too. Just to make it tidy.
00tibby Oct 12, 2004 05:02 PM
Re: My aliminum crank pulley
wats the result of the clearance?
spiceflow Oct 12, 2004 07:00 PM
Re: NEW CIVIC SONG!
<div class='quotetop'>QUOTE (00Tibby)</div><div class='quotemain'>wats the result of the clearance?</div>
Oh yeah! I forgot to update this. oops.gif After several months, I don't see any signs of damage or wear on the wire that goes under the hood support. So it should be just fine there.
Shadohh Dec 10, 2004 12:51 PM
Re: What exactly does a SAFC 2 do?
I see some flaws in your design.
While it is good to run a bigger cable from the ALT to the battery it also needs a fuse. The regular inline fuse is 100AMP And from what I see you have no fuse at all. This has the potential of hhurting the battery and/or ALT.
http://hmaservice.com/xml/graphics/E2/E27B309A.jpg
The cable connector you changed is E31-1
And if you ddint leave the original installed the ALT is losing its sensing ability and over charging the battery this will cause it die quicker. And will put more straing on the ALT and thats means less HP.
I just think this should be addressed we dont want any tib owners stranded off to the side of the road.
Your ground points seem alright. Thou I would add one to the back of the firewall near the brake booster since most of the ground points for the engine sensor all run lines back to that point.
