clock lense install
Hi! i drop this message to ask if there is a fast way to remove ONLY the clock (from behind) without taking off everything else.. thanks wink1.gif
<div class='quotetop'>QUOTE (Mr_Hyde_NT)</div><div class='quotemain'>Hi! i drop this message to ask if there is a fast way to remove ONLY the clock (from behind) without taking off everything else.. thanks wink1.gif</div>
Unfortunately not
You have to take the dash off
Unfortunately not
well you dont have to remove the entire dash to get to the instrument cluster......however you prob wont have enough room to remove the clock w/o disconnecting everything....sorry
I'm sure I could, but if you dont know the answer to your question already, then chances are you could not. if you can see with your fingers, and really know where everything is at back there, a short philips head driver would do just find to pull out the two screws in back of the clock.
But to be honest, I've pulled dashes completely off, fixed a problem and had them back bolted on with everything else assembled in less than 10 minutes, so its really just a matter of paying attention and just doing it, its not really up there with the more difficult things, its just like a big panel.
<div class='quotetop'>QUOTE </div><div class='quotemain'>in less than 10 minutes</div>
8O only ?!
well! good to hear this.. i 'll try to do do it soon.
Do you want to know where i found the blue plastic cover for the clock ? lol.gif ..from the extra mint TIC TAC box (the blue one)
8O only ?!
<div class='quotetop'>QUOTE </div><div class='quotemain'>Do you want to know where i found the blue plastic cover for the clock ? ..from the extra mint TIC TAC box (the blue one)
...a really expensive mod, just .50cent </div>
That's a good idea. I'll have to try that!!!
You can also use colored folder tabs for clock lenses, etc. I got 24 of them in a pack (Red, Blue & Yellow) for like $1.29. And of course they are very easy to cut to the size needed.
