Good Android Tools
I would like to start a list of must-have Android tools. I'm not talking about apps which let you display your gamer tag on your home screen. I'm talking about serious tools. What good apps are there?
Android Terminal: Lets you interface with a Bourne-Again SHell (BASH). A powerful shell app which allows you to design custom scripts to reorganize data, access devices directly, and search around inside the filesystem.
android-flashlight: turns the LCD into a flashlight. So far I have not found one which lets you use a camera LED as a flashlight.
wardrive v3.7: marks on a map unsecured wireless internet applications which allows you to quickly locate the nearest unsecured wifi hotspot
Speedtest.net: utilizes the same servers as Firefox, but in a Android screen friendly application, giving you the ping time and speed of the connection
android-vnc-viewer: allows you to interface with your Linux/Mac computer at home using the pinch interface, touchscreen and keyboard.
USAA app: for USAA customers only, allows you to take a picture of a check and deposits. Then you write VOID on the check.
So lets hear it.. I'm switching to Android soon and I'd like to hear about the cool stuff which I don't know about.
+1 on the task killer
shop savvy - saved some coin using this program
pandora - good radio program
weatherbug - works better sometimes than the weather channel widget
bloo - better version of facebook for the droid
convert pad - converts all sorts of measurements
google sky map - want to know what that is blinking in the sky? this will tell you what star or planet it is by holding the phone up to the area.
layar
layar
3D Level - allows you to graphically see the level of the tilt sensors. Useful as a way to level objects, assuming your phone has a flat surface.
^^^i was going to suggest that but didnt know how many people actually use their phone as a level.
another good level is the Johnson brand level. i use it to level my target archery bows if that tells you anything.
<div class='quotetop'>QUOTE (faithofadragon @ Aug 8 2010, 12:17 PM) <{POST_SNAPBACK}></div><div class='quotemain'>the led flashlight app can ruin the flash
so you gotta be careful with that</div>
Really? How so? I don't doubt it, just never heard that before.
<div class='quotetop'>QUOTE (EclipseMTL @ Aug 8 2010, 12:14 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Dtn, if you search for droidlight led flashlight, its a free app from motorola that does in fact let youu. Use. The camera led, it works pretty well!</div>
It probably only works if you have a Motorola phone. "FlashApp" works for the HTC Evo, uses either the small LED (constant) or brighter LED (it flashes only)
