X3 excel (accent) brake upgrade
Vehicle: 97 x3 excel twin cam
Hi everyone, new to the forum. just bought a 97 x3 excel (accent) twin cam to get me to work and back as i work pretty far away and needed something a bit more fuel efficient. car is in really really good nick, not planning anything major in it just a few small things so i was wondering what other hyundai's i can get parts for to do a big brake upgrade, front and rear discs. searched the forum but most posts are about later model accents and things.
any help would be awesome thanks
Unless you're putting down serious power or going to the track to race every weekend, a big brake upgrade really isn't worth it. If you upgrade your factory brakes with good quality slotted front discs and put 4 good brake pads in all 4 corners, that's really all you need. You could also invest in stainless steel brake lines and with just those things, your brakes will be like night and day different from the factory brakes.
In the front you can swap the entire knuckle from any RD, preferible 2000+ because the rotor is free floating.
That will take you from 9" to a 10" rotor.
X3 Rotor : http://www.rockauto....1170739&jsn=508
RD2 Rotor: http://www.rockauto.com/en/moreinfo....363159&jsn=366
On the back it can also be converted from an RD2, but a little fabrication is involved.
In the front you can also go to 11" or 12", and single piston, dual piston or single piston aluminum calipers mixing and matching parts from GKs and Sonatas
