Wich Wheels Will Fill My Fender Flare?
^indeed...
If you need spacers anyway, and don't want to get custom wheels ($$$), I would fabricate a spacer with a different bolt pattern, and get some awsome deep 5 lug wheels from ebay or somewhere...
Building such a converter is relatively easy for a pro fabricator (cnc?).
It has holes to (or bolts in our case) to bolt it to the car, and has bolts sticking out with the needed pattern.
It is not the BEST solution, but I see it work...
120mm dish = 4.75" = YUK in my book..
90mm dish = 3.50" = too big
something up to around a 2" dish would be ok, but that deep of a dish, i really don't like, but its your car, so do what makes you happy.
just don't think it would look right on a tib at all, but to each is own.
id look into a cheaper rim with a different offset than stock and use some sort of a spacer. like a ~30offset 17x8 with a 1.25" spacer. should have em sit almost flush and relatively easy to find.
