Hyundai Aftermarket
-   Braking, Wheels, Tires, Suspension (https://www.hyundaiaftermarket.org/forum/braking-wheels-tires-suspension-12/)
-   -   Wheel Bearing Replacement (https://www.hyundaiaftermarket.org/forum/braking-wheels-tires-suspension-12/wheel-bearing-replacement-83224/)
JelloStorm Oct 25, 2017 12:27 PM
If you have a wheel bearing with a tiny tiny bit of play, how much of a risk is it to drive on it for awhile? It's not making noise and it's not causing any steering problems. I was going to have it replaced in around a month and just want to make sure I'm not taking any major risks driving around with it the way it is.
Stocker Oct 26, 2017 06:25 PM
It's a gamble but it's gotten this bad without falling apart, hasn't it? It could fail tomorrow so nobody is going to seriously tell you to "keep driving it, it'll be fine!" . . . but it could also go maybe a couple of years more.
Are you *sure* it's a bad bearing? It is easy to do a "wiggle the tire" test wrong and think you have a bad bearing when you're just moving the suspension or steering.
Boston Red Veloster Nov 8, 2017 07:11 AM
I wouldnt risk it. Last thing you want is your wheel flying off when you're doing 65 down the highway.
