Hyundai Aftermarket
-   Braking, Wheels, Tires, Suspension (https://www.hyundaiaftermarket.org/forum/braking-wheels-tires-suspension-12/)
-   -   squeling w/ strut bars (https://www.hyundaiaftermarket.org/forum/braking-wheels-tires-suspension-12/squeling-w-strut-bars-25645/)
brian01tib Jan 10, 2005 02:11 PM
I got the front and rear strut bars and when I went around turns normal speed about 35-40 there was a small squel from the back inside tire, they made it so there was no more body roll, I was driving in slow traffic before hand so the tires may have not warmed up yet. is it this or the strut bars
it was squel but felt in control. thanks
UltraTibby Jan 10, 2005 02:15 PM
I dont have the strut bars but I have had the squeel before. It has happened when I had the rear tires over inflated. It was making the back end basically start to come loose.
LarryMcFly Jan 10, 2005 02:39 PM
Well, strut bars limit body flex so the forces on the tires are not applied the same way as before when cornering.
Mad-Machine Jan 10, 2005 06:06 PM
strut bars are on my list.. but I almost hate to think what they are going to do to the handling of my Tib.. as she is set up now.. I have no problems bringing the rear around.
hamhead Jan 10, 2005 06:11 PM
Same here. I took the Tib out for a little bit of handling for the first time the other day. Wanted to see if it was up to the hype, and it was pretty good for a under-powered FWD car. I own the Civics in the twisties. Course stock tires are no good either. I'm glad my Tibby has no ABS though, one of the props of buying a entry-level Tibby. No ABS is worth more than a moon-roof and leather seats any day. laugh.gif
Mad-Machine Jan 10, 2005 06:14 PM
yes, the lack of ABS does wonders for bringing the rear around in a tight corner.. must be the reason I go through rear brakes and tyres faster than the fronts
brian01tib Jan 13, 2005 01:59 PM
In the turn there was less lean, bodyroll, I like them a lot because of this
I would rather have a quick chirp than bodyroll It helped bring the rear around very controlable
01tibby Jan 13, 2005 04:21 PM
<div class='quotetop'>QUOTE (hamhead)</div><div class='quotemain'>Same here. I took the Tib out for a little bit of handling for the first time the other day. Wanted to see if it was up to the hype, and it was pretty good for a under-powered FWD car. I own the Civics in the twisties. Course stock tires are no good either. I'm glad my Tibby has no ABS though, one of the props of buying a entry-level Tibby. No ABS is worth more than a moon-roof and leather seats any day. laugh.gif</div>
how about no abs plus a moonroof and leather interior.
REDZMAN Jan 13, 2005 04:26 PM
What's a squel?
I've never seen a RD with ABS.
Mad-Machine Jan 13, 2005 05:08 PM
I think it was an option on the last year (99) FX.. mine has the light and it is mentioned in the owner's manual.. but being an non-FX, I do not have it.
