Screw in rear rotor?
Old Jul 31, 2004 | 07:11 PM
Lil Tiby's Avatar
Default Re: Turn Signal bulb?
What is it there for? Does it MAINLY hold the rotor on or does it just assist? Is it in both rear rotors and if so have any of you had a rim issue? I have been waiting on rims because this looks as if it's going to be a problem and interferrence.
TIA
Old Jul 31, 2004 | 07:13 PM
Dweet's Avatar
Default Screw in rear rotor?
remove it.. it wont hurt anything.. they are in both rear rotors and will possibly cause fitment issues so just take them out
Old Jul 31, 2004 | 07:44 PM
Sparticus's Avatar
Vehicle: 97 Tiburon
Default Re: M3 Mirrors?
they hold the hub to the rotor (barely)... but your hub won't fall off if there are 4 lug nuts holding the rim in place. lol.
take 'em off. take 'em ALLLL off
Old Aug 1, 2004 | 07:42 AM
Default Re: Beta 1 Superchargers?
yea.. it is only there to keep the rotor to the hub when the wheel and caliper are removed. More than likely it is there to help in production.
Old Aug 3, 2004 | 01:59 PM
Lil Tiby's Avatar
Default Re: Went to the track again :)
sweet...thx everyone!
also...can anyone tell me exactly what offset is when it comes to rims?? i want to get 18's ideally but would the offset be the same no matter what?
Old Aug 3, 2004 | 04:23 PM
JalemX's Avatar
Default Re: Recalibrate The Speedo
offset = how far the wheels sticks out from ur car, your gonna wanna look @ the offset and the width of the wheel, but as far as takin the screw out , i had to chisel mine out then sand it down nice and smooth. You're not gonna be able to put on aftermarket wheels if you dont. If you got a RD2 itll be ok to take out, if its a RD1 and non-captive break setup you are also ok
Old Aug 3, 2004 | 07:57 PM
KayJai's Avatar
Default Re: WTB: Stock RD2 Wheels
+40 to +42 on 17's for your offset will be fine
17"X7" Wheels
Old Aug 4, 2004 | 07:49 AM
blue2000's Avatar
Vehicle: 2K Tib
Default Re: North East Chapter Members
Basic explaination of offset:
http://www.lexusownersclub.co.uk/forum/ind...howtopic=11821&
Explaination with pictures:
http://www.topbuzz1.carenthusiasts.co.uk/i...fset/offset.htm
Stock offset is 45mm. The lowest offset I've read of anyone using with 205 width tires is 35mm.
Old Aug 4, 2004 | 09:46 AM
Default Re: HID Kit
We need to get offsets and stuff like this put into the FAQ.
Old Aug 4, 2004 | 01:40 PM
blue2000's Avatar
Vehicle: 2K Tib
Default Re: my little CEL problem
hey, I had all this stuff in a sticky thread in the old forum...but someone went and changed things without askin' me first. So tongue.gif on your FAQ. lol.gif
