Rear Rotor
Old Sep 8, 2004 | 03:24 PM
Hanguk9117's Avatar
Default Re: EBC Greenstuff
Alright, so i got the rotors from majiktib. i took the rear calipers off, and then tried to take the rear rotors off but im not sure how. the front rotors just come off once the calipers are off, but the rears are still stuck. how do i take the rear rotors off a 2001 tib?
Old Sep 8, 2004 | 03:46 PM
Default Re: Wheels...ebay...help!
are there 2 screws holding the rotors on? If so, take them out. I had to dremel mine off when I first put my rims on... just cut the heads off and it was easy after that. You might just have to pull harder wink.gif
other than that, I'm not sure :? sorry
Old Sep 8, 2004 | 04:40 PM
Hanguk9117's Avatar
Default Re: 10+ Body kits assorted GB
yah i cut those 2 screws long ago too when i got my first set of rims. so all i need to do is pull hard on the rear rotor and it SHOULD come off rite? there isn't anything else i need to take off or unscrew?
Old Sep 8, 2004 | 04:48 PM
JalemX's Avatar
Default Re: FS: Custom COLORED Shift Boots!
yea man you have to rip that shit off. That's the only way its coming lol.
Go get the BIG MALLOT HAMMER!!
Old Sep 8, 2004 | 05:43 PM
canadianshark74's Avatar
Default Re: Standalone
the rear rotors are a biatch to get off the hub, they rust together (rotor and hub) you will need a lot of elbow grease. the shop that did my rear brakes, took the rear rotors off in pieces, with a torch.
good luck
Old Sep 8, 2004 | 05:58 PM
Default Re: Custom Decals
maybe the salt from the ocean has caused rust. I was thinking since you were in sunny california that you wouldn't have a problem, but I didn't take into consideration salt in the air.
You may have a bit of rust... I know Tibby01 had a bit of trouble with his rusted rotors!
...searching old site for pics....
Edit:
I know there are more pics, but this is the only one I could find.
Old Sep 8, 2004 | 06:17 PM
Hanguk9117's Avatar
Default Re: South Chapter Members edit
woaaaaaaaaaaaaaaaaaa. OUCH. crazy. i hope i dont have to get TAHT crazy. but i guess we'll see? dang, thats some serious damage... 8O
Old Sep 9, 2004 | 11:42 AM
Default Re: Wiring harness w/aftermarket bulbs?
yeah, it was fun. :twisted:
check out this thread for ideas.
http://www.hyundaiaftermarket.com/cgi-bin/...t=001030#000005
Old Sep 9, 2004 | 12:37 PM
Dweet's Avatar
PB blaster is your friend
Old Sep 12, 2004 | 05:32 AM
Hanguk9117's Avatar
Default Re: Timing the timing belt?
dang i feel bad for yah east coast peoples...
