Silver or black? Do black rims chip? 14X4.5 lug pattern w/ 40 offset correct? Doing some final checks. 17x7 should fit over oem correct?
http://www.wheelmax.com/_images/prod...-RADIUS-BK.gif http://www.wheelmax.com/_images/prod...L-LIGHT-HL.gif |
I didnt find any info on the weight of that wheel. If you are NA or will have any inkling in the future to begin to boost performance, NOW is the time to act. Id suggest finding a similar style in a more reputable company, (Konig, Centerline, etc...) and find a wheel with at least a ratio of 1:1 ( inch diameter:lbs per wheel ) IE: a 17 inch rim should weigh in the neighborhood of around 17 lbs. Less is even better! My 17" Centerline rims weigh in at 16 lbs. Before that I had some no name 18" rims that weighed 28 lbs per rim!!! Simply upgrading those 18's to the light weight 17's made my car feel like it had a complete engine and suspension overhaul!
AS far as the style, I like it! Very similar to the Centerlines I have on my car now. I believe your bolt patterns and offsets are correct. someone else chime in here to verify please.... |
editted a little. useful advice ill keep in mind ..N/A at the moment, thanks
bolt pattern is 4x114.3...whatever rim you decide to get make sure you get some hubcentric rings
i like the black with polished lip, i think they will look real nice, just my opinion
get the silver ones. but centerline mkaes a rim just like that that is forged and lightweight.
not to hijack this thread but how important are hub centric rings? I don't have them and don't get any wheel wobble. Is that mainly what they're for?
To stay on topic I'd go with the black rims. |
i would also go with the black rims
our lug pattern is 4 x 114.3? i could've sworn it was 4 x 100? |
The Black w/ polished look so good on so many colors
Personally I would go with something that had fewer spokes but that's just my taste. |
