Camber bolt question
I have noticed when replacing struts on the Accent their is no way to adjust the camber bolts. They are just strIght bolts. My question is, is there no way adjust the toe/camber without buying aftermarket camber bolts?
The holes aren't round, they're slightly slotted giving you some ability to adjust camber. It's only a minor amount though and anything beyond that requires camber bolts. Toe is adjusted in the steering linkage.
