need help with 2004 rotor upgrade
Old 04-05-2018, 09:36 AM
x3racer's Avatar
Vehicle: 1996 accent gt
Default need help with 2004 rotor upgrade
hi folks , my problem is i have two sets of 15x7 4x114.3 rota slipstreams from my old x3 which wont fit the 4x100 rotor . does anyone know if there is a bolt on rotor from an elantra or other car that would fit my lc 2004 ?
thanks
x3
Old 04-11-2018, 06:52 PM
Juanra's Avatar
You can swap the entire front knuckle out a RD/RD2, and the rear is depends on if you want to stay with drums or convert to rear disk brakes.
If you want to upgrade the rear brakes to discs you will need to fabricate the mount for the calipers and swap out the emergency cables.
If you want to keep the drums you can what out the hub and other components from X3 or RDs.
