Need help
Old 01-07-2018, 10:15 PM
Jjtek's Avatar
Vehicle: Hyundai Accent 95
Default Need help
Hello. Guys i have a Hyundai Accent 96. I am trying to swap a v6 engine just want to know what do it need to do and what I need. To swap it and have it running
Old 01-08-2018, 05:45 AM
Moving this to the Hybrid forum....
Old 01-08-2018, 05:48 AM
Dropping a V6 into an Accent isn't the best option. It'll be too heavy and way too complicated. Since your profile is showing you have a 95 Accent, you're best option is to drop in either a 1.8 or 2.0 4 cylinder beta engine from a Tiburon or Elantra. It's been done hundreds of times with ease and simplicity. It'll give you a lot more power (especially if you decide to turbo the beta engine), and it wont hurt your handling or bank account as much as a V6. If you do a search for Beta Swap, you'll find more info on here than you can shake a stick at. If you have any other questions about it, let us know. This is something people here are experts in and can definitely steer you in the right direction or give guidance on.
Also...follow this thread to get A LOT of great info:
https://www.hyundaiaftermarket.org/f...-the-race-egg/
Old 01-08-2018, 02:15 PM
V6 swaps have been done. The 2.7l and 3.5l Hyundai V6 can fit under the hood of the LC/LC2 (2000-2005) Accent, but I can't recall seeing one installed in an X3 like yours. It would probably fit. There probably won't be anyone here that can give much assistance.
As Visionz stated though, the 2.0l is a better route. You can swap it in and still have enough room for a turbo, and that will handily beat any V6 swap that would be feasible. Anything is possible with enough time, money, and effort, but the 2.0l swap would be a better investment.
Old 01-09-2018, 12:45 PM
Juanra's Avatar
I have seen 2.7L Deltas and 3.8L 6G75 MIVEC. Everything has to be custom made and you have to reinforce the "chassis".
