Transmission swap
Old 08-30-2017, 05:16 AM
Richter44's Avatar
Vehicle: 96 Coupe
Default Transmission swap
Hi, all.
I have a 7/96 SX coupe 1.8ltr 5-speed manual. The transmission is done.
Will other transmissions bolt up to the 1.8ltr G4GF engine?
Like can I use a 2.0ltr from a 98 coupe ect.
Thank you
Old 08-30-2017, 05:26 AM
Yes, they use the same block, so any transmission will work. You can even go into the 2002+ years.
Old 08-30-2017, 06:38 AM
Richter44's Avatar
Vehicle: 96 Coupe
Thanks man. Found a 1998 2.0ltr complete car with 174000kms on it for $500.
would the 2.0ltr engine drop straight in to?
Old 08-30-2017, 06:43 AM
Yes, that would be a worthwhile swap. Little high mileage, but I doubt you'd find any better considering how old the cars are. If you're mechanically inclined, and have the time, I would do a fresh rebuild on the motor with new oil/water pump, rings, etc.
