Is there a way to monitor transmission temperature?
Old 07-31-2017, 01:09 PM
WRC_Accent's Avatar
Vehicle: 2000 Accent
Default Is there a way to monitor transmission temperature?
I'd like to know how hot my transmission is getting on race days. Is there any way to do that easily?
Old 07-31-2017, 01:37 PM
Juanra's Avatar
I would say tap a sensor in. in the manual I would use the same screw used to empty the fluid in the automatic I would use the line that goes to the cooler...
Old 08-15-2017, 03:14 PM
thor420's Avatar
If it's data that your OBD ECU reads then you could use an app like torque and have a digital gauge of the transmission temp.
