Hyundai and Kia recall 1.2M cars for possible engine failure
Old 04-07-2017, 09:55 AM
Default Hyundai and Kia recall 1.2M cars for possible engine failure
FYI....
April 07, 2017 08:48 AM
DETROIT (AP) - Hyundai and Kia are recalling nearly 1.2 million cars and SUVs because the engines can fail and stall, increasing the risk of a crash.
The recall covers the Korean automakers' most popular models including 2013 and 2014 Hyundai Santa Fe Sport SUVs and Sonata midsize cars. Also covered are Kia Optima midsize cars from 2011 through 2014, Kia Sportage SUVs from 2011 through 2013 and Kia Sorento SUVs from 2012 through 2014.
The companies say that debris left from manufacturing can restrict oil flow to connecting rod bearings. That can increase temperatures and cause the bearings to wear and fail.
Hyundai and Kia will notify owners and dealers will inspect the engines. They'll replace the block if needed at no cost. The recall is scheduled to start on May 19.
(Copyright 2017 The Associated Press. All rights reserved. This material may not be published, broadcast, rewritten or redistributed.)
Old 04-07-2017, 10:40 AM
I don't get it. If there's debree left over, then it should be in the pan by now. And if it gets picked up, then it should get filtered. Unless it's large enough to clog the pickup screen?
Old 04-07-2017, 02:57 PM
If the debris is in the oil passages leading to the rod bearings (the crank drillings), it only needs to be larger than the rod bearing clearance (about .002) to plug up the passages. It would never make it to the pan.
