Giggle giggle
Vehicle: 2000 Tiburon
Be careful your floor pans don't fall out or else the mad scientist will have to rip apart the block and replace the piston rings you fried. But only if they are able to overnight parts from Jah-pan.
Vehicle: Gen Coupe 2.0 Track
Be careful spraying that on a 2.0. The intake manifold has unequal length runners so cylinder 1 will get a ton of fuel and cylinder 4 will run lean which will cause an atomic bomb.
