Need a new clutch
Old 05-30-2016, 03:41 PM
Dyson's Avatar
Vehicle: 2007 Accent
Default Need a new clutch
My clutch is finally starting to slip in higher gears a little so that means it's on the way out. What do you guys recommend for a new one? I just have basic mods done so should I get another factory clutch or get one of the ones that can handle a little more horsepower (stage 1 or 2 clutches)?
Old 05-30-2016, 06:51 PM
2000J25SP's Avatar
Exedy oe replacement.
Old 05-31-2016, 07:23 PM
If the stock clutch has been good-enough for a decent amount of miles, go for a stock replacement.
Old 06-28-2016, 09:21 AM
Tibchamp83's Avatar
Vehicle: 2006 Tiburon
i would play it safe and get one thats rated a little more than your horsepower. you never know when you will add more to the car so having a clutch that can handle is good. its better to have a clutch that can work with what you have than having to buy another one sooner than you wanted because you decided to do something that needs the clutch to hold.
