1.8l cam and pistons in 2.0l
To rephrase: the exhaust cams are the same, and the intake cams can be swapped with no problem. I have yet to see a dyno before/after, but the 1.8L cam has a slightly higher lift and longer duration, so there should be mild gains using that part.
The 1.8L pistons have a higher crown, and can be used on 2.0L rods for increased compression.
