Converting returnless fuel system to return
Old 01-16-2016, 06:19 PM
accent_01's Avatar
Vehicle: 01 Accent
Default Converting returnless fuel system to return
What would i need to do this, im going to buy a new steel fuel rail, how should i go about running the return line, what type of hose should i use?
Old 01-16-2016, 06:35 PM
no_name's Avatar
Vehicle: 2005 Accent GSI
I would really like to know why you want to do this. It will most likely just prevent your car from passing an emissions test.
Old 01-16-2016, 07:13 PM
You don't run a return line. You run a larger feed line and use your old feed line as the return line.
