Transmission swap wiring
Old 01-03-2016, 08:54 AM
fronkkillsit's Avatar
Default Transmission swap wiring
Coming close to having everything I need for the swap. All I have left to get is the transmission itself and a clutch. I need help with wiring the neutral safety switch and reverse lights. 2000 tiburon.
Old 01-04-2016, 06:48 PM
useful information in my swap thread starts about here
https://www.hyundaiaftermarket.org/f...55#entry539755
wiring information you might want to know about in post #36
look also especially in #47 and #49 for wiring notes
Old 01-04-2016, 10:28 PM
Thanks!
Old 01-04-2016, 10:41 PM
My only thing is the neutral safety and reverse lights. Do they have to be wired in a certain way with the four pins on the range switch or is one a hot and one a ground?
