need help fast
Old 04-24-2015, 05:36 PM
evillow's Avatar
Vehicle: 00 hyundai accent (beta swap in process)
Default need help fast
Ok guys I have a 00 lc 1.5l I just rebuilt the motor machine shop work and all it Will start and run for 3 seconds and then die. If I hold the gas pedal it will run but sound rough and as soon as you let go it dies I have been able to get codes multiple misfires, misfire cylinder 1, misfire cylinder 2, and misfire cylinder 4 I have put brand new plugs (copper core ngk), wires coils, crank sensor, cam sensor, iac, tps, maf and the injectors all have new orings it also has ntk o2 sensors that might have 1000 miles on them can someone please help me. I'm lost
Old 04-24-2015, 05:37 PM
03-accent-03's Avatar
Vehicle: 03 Hyundai Accent
It sounds like it's not getting enough fuel. Check your fuel pump. Your fuel filter too.
Old 04-24-2015, 07:05 PM
no_name's Avatar
Vehicle: 2005 Accent GSI
Could the fuel/spark timing be off?
Old 04-24-2015, 08:24 PM
im goin to go with timing.
Old 04-25-2015, 07:35 AM
Could be a bad vacuum leak. Check all hoses are connected. Also check the idle motor.
Old 04-26-2015, 08:03 AM
SR Tech's Avatar
Vehicle: 2011 Tuscon
This^
Double check your timing marks
Old 04-27-2015, 11:23 AM
The only time I've had this EXACT problem it was a serious vacuum leak. The key similarity being running for a few seconds then dying unless you really play with the throttle.
Also triple check the wires and firing order.
