Is the stock head gasket fine for nitrous use?
Vehicle: 99 tiburon
Thinking about pulling the trigger on an NX wet kit and was wondering if the stock head gasket is perfectly fine for nitrous use or should it be upgraded to something better? I'm only thinking about using a 65 or 70 shot. I'll upgrade my fuel pump to a Walboro also for extra fuel delivery.
Read up as much as you can. People have sprayed 75-100 shots on the stock motor. You can spray up to a 50 shot before running out of fuel. Then get a 190lph walbro. Spray a 60-75 shot and the clutch will slip. Don't bother spraying in 1st gear. After a 75 shot, tighten the plug gap to .022. Beyond that, just build a turbo kit because you'll get tired of filling the bottle.
THIS INFO IS ASSUMING YOU ARE TALKING ABOUT THE 1999 TIB IN YOUR PROFILE
BEFORE spraying run a compression test. make sure you got a healthy motor.
gsx fuel pump is a cheap upgrade too that wont require a regulator
run BKR7E-11 ngk spark plugs and if you are heavy with the spray (and you will be...) replace em like every other oil change. they are hella cheap. like....$8 for a set.
get a TEMPERATURE CONTROLLED bottle blanket. youll want one.
and a window switch is really nice to have. same with a remote bottle opener. but not necessary.
