Is there a way to remove orange peel without wet sanding?
Old 02-27-2015, 01:05 PM
Elantra66's Avatar
Vehicle: 2001 Elantra
Default Is there a way to remove orange peel without wet sanding?
I have searched through out the forum for the answer on this and everyone says to remove orange peel, you have to wet sand. Is there something else I can do to remove it? I dont feel comfortable taking sand paper to my paint so I'm hoping there's some type of stuff I can buy in a bottle that I wipe on and wipe off to make life easier.
Old 02-27-2015, 06:26 PM
If you have orange peel, you aren't sanding your paint you are sanding the BAD paint on top of your paint. It's a physical mass and the only way to remove it is either mechanically (sandpaper) or chemically (stripper). I bet if you are leery of sandpaper you really don't want to strip the whole thing to metal, so sandpaper is going to be your answer. Use a finer grit than you think you need and take a long time if you are worried about taking off too much paint.
