Beta 1 2.0l exhaust cam on the intake said
Old 11-27-2014, 05:49 PM
BryanFX's Avatar
Vehicle: 1998 Hyundai Tiburon Fx
Default Beta 1 2.0l exhaust cam on the intake said
Can anybody help with this mod on engine. I have read that people put the exhaust cam on the intake side with some modification on the cam.
I have done my re search onthis but cant find nothing please help.
Here a link were they talk about it:
http://www.newtiburon.com/forums/i4-.../191830?page=1
Old 11-27-2014, 06:20 PM
That seems like a metric crap ton of work for something that might not work anyway. Only one of the beta cams is driven by the belt so having two for the same type might not be possible from the get go - before getting into cam profiles/timing, etc
Old 11-28-2014, 02:11 PM
BryanFX's Avatar
Thanks, but it's possible to doit I'll try de mod and keep looking on the forums to guide my self
Doing something different from the 1.8 intake cam swap etc.
Old 11-28-2014, 06:40 PM
SpoolinShark's Avatar
Vehicle: 2010 Hyundai Accent
I've also been considering doing it as well since it has higher lift and longer duration. Seems pretty straight forward but I wonder when the valves would open after the swap. Guess best bet would be to use a cam degree wheel.
Old 11-29-2014, 03:10 PM
slow 2K2GT's Avatar
Vehicle: 2003 Hyundai Tiburon i4
If you do a side by side of any cam set the intake and exhaust are identical, minus the obvious VERY minor deviations in duration and lift. The cam mod in question is common and relatively easy if you have the right machinist to get the cam timing lug put in the correct spot.
Old 11-30-2014, 10:00 AM
BryanFX's Avatar
Ok, so I was thinking can the stock valve train handle the extra lift and duration from the cam?
Old 11-30-2014, 11:04 AM
Yes, the stock valvetrain will hold up fine. It is a stock cam so nothing really is changing. To ease your mind, members have ran much higher lift cams on stock valvetrain without issues as well.
Old 11-30-2014, 11:19 AM
BryanFX's Avatar
Thanks a lot guys for the help
Old 12-10-2014, 04:34 AM
blitz's Avatar
Vehicle: 97' Hyundai Coupe
I'm using the 1.8 cam right now , but was also thinking about 2.0 exhaust cam... Wasn't sure back then, not that I'm now but might give it a try !
Old 12-11-2014, 09:05 AM
Juanra's Avatar
I have that in my car right now, the most difficult part is having the pin for the cam sensor fabricated.
Quick Reply: Beta 1 2.0l exhaust cam on the intake said
