Fuel Filter with a demon
Old 09-13-2014, 03:33 PM
touchless2506's Avatar
Vehicle: 1998 Hyundai Tiburon Fx
Default Fuel Filter with a demon
I bought a fuel filter from Autozone. The top fitting would not seat properly on it. Took it back and tried putting the old one on. It mated nice and looked to have seated good. Started it up and there is a pin hole leak coming between the mating surfaces. Now, the fitting slides in and out pretty easily, something tells me that is not correct. And why does it leak? How do I fix it?
Old 09-13-2014, 03:37 PM
20140913_114344.jpg40913_114344.jpg]
File Type: jpg
Old 09-13-2014, 07:14 PM
pandaturbo2's Avatar
Vehicle: 99 Hyundai Lantra
O-ring
Old 09-13-2014, 07:57 PM
Really? I was thinking that or maybe the flare on the fitting needed help. But o-ring is a good idea. I didn't see one when I pulled it apart. I suppose it would need to be a fuel treated one. I'll try it. Thanks.
Old 09-14-2014, 01:55 AM
Yea needs to be fuel rated. O ring should be on the pipe that goes into the filter from memory.
Old 09-14-2014, 01:15 PM
Hopefully it is clear enough.
Old 09-14-2014, 06:37 PM
I have it all figured. Took a chance and tried an o-ring. Ran it hard and found no leaks. It goes on the base or shown as choice B.Thanks.
Old 09-15-2014, 01:09 AM
Should be the gap where A is.
Old 09-15-2014, 08:48 PM
Oh. Should I take it apart and find ine that fits there?
Old 09-15-2014, 09:42 PM
In theory, yes. In practice if it were my car, probably not if it doesn't leak
