Cooling fan not coming on
Old 09-07-2014, 05:03 PM
colescars's Avatar
Vehicle: 2003 Tiburon
Default Cooling fan not coming on
Hi,
I have a 2003 Tiburon with a heating problem. The cooling fan is not coming on and no temperature gauge reading. I have replaced the fan, relays, fuses and temperature sending unit. No go. Any suggestions on what the issue might be?
Thanks in advance
Old 09-07-2014, 05:37 PM
Charley's Avatar
Vehicle: 2006 Tiburon
Water pump? Bad radiator? Thermostat? Those could all cause those types of issues.
Old 09-07-2014, 07:58 PM
Do all the rest of the gauges work properly?
Old 09-08-2014, 10:11 AM
Could be a bad "new" temp sending unit. Been there, done that. If its an easy exchange, go get another one to rule that out. Otherwise, I'm sure you could test with a multi meter.
I would think that even with a faulty radiator or thermostat you would get some kind of temp reading. Bad water pump maybe, but I would imagine you would have heard howling or extra noise on that side of the engine prior to this problem.
