Instrument cluster bulbs
Old 06-02-2014, 10:04 PM
bigfishmoney's Avatar
Default Instrument cluster bulbs
for a 2001 Tiburon what lights/bulbs should I expect to buy to replace all instrument cluster lights(gas, coolant tenp, speedo and rpm backlights) ??
I used search function and have found I need 74 73 194 168 bulbs
how many bulbs are needed in all??
Old 06-13-2014, 09:44 AM
Solved this
Old 06-13-2014, 01:05 PM
onecrazyfoo4u's Avatar
So what did you end up needing? I've been thinking about replacing the gauge cluster bulbs with LED's to look more white and less yellow in color. From researching this is what I show a 2001 Tib would need:
4x T10 (or 194) bulbs and 2x T5 bulbs
Was that what you ended up needing to do the whole instrument gauge cluster?
Old 06-17-2014, 01:06 PM
Herrrro?
Old 07-29-2014, 09:45 PM
So I replaced all except lights around the outside with Sylvania 168, 74 and they all turned out amber or incandescent
Thanks U are correct there though
Old 07-29-2014, 09:53 PM
Originally Posted by onecrazyfoo4u
Herrrro?
168, yes I mean 194
Old 07-29-2014, 09:59 PM
Not the entire instrument cluster only the 6
Not the Check engine bulb family of black colored twist lock 74s
Old 07-30-2014, 02:37 PM
So trying to piece together your responses...you need 6 "194" bulbs for the instrument cluster lighting only?
What locations take the 74 bulb?
Old 07-30-2014, 03:20 PM
168(4) large black twist lock 74(2) small grey twist lock
i found 74 bulbs go right behind the coolant and gas gauge hands. directly behind them on the back of the instrument cluster
the really small black twist locks are smaller than the grey twist locks that look the same but are smaller by a very small measure
Old 07-30-2014, 04:05 PM
Okay cool, thanks for the info!
