auto to manual swap issues
Old 04-17-2014, 09:56 AM
<little shark>'s Avatar
Vehicle: 2001 tuburon RD
Default auto to manual swap issues
i recently purchased an 01 tiburon rd, the previous owner did an auto to manual tranny swap, the issues im having are, the original auto tranny wiring harness, the TPS, IAC, o2 sensors are all reportedly new, a pin on the o2 sensor connector( i dont know if its plugged in the ecu or fuse panel). its throwing a p0134 and p0506 codes and the dreaded honda idle(1500-2000-1500), the idle hangs around 1500 then drops to 1000rpms after ive come to a stop. anyone with a pin or wiring diagram to fix this issue please help. thanks in advance
