Swapping doors
Old 04-02-2014, 06:05 PM
Charley's Avatar
Vehicle: 2006 Tiburon
Default Swapping doors
Both of my doors have some small rust spots on the bottom of them. Instead of trying to fix it, I found a set of doors at a local car yard that are the same color as my car. So how hard is it to remove the doors and put the new ones on? Can I do it myself or is it really a 2 or 3 person job?
Old 04-02-2014, 08:32 PM
nos4atu's Avatar
It's do-able on one's own, but easier with a friend. I've done mine on my own. Pretty simple, seven bolts and a harness iirc.
Old 04-02-2014, 08:34 PM
You *could* but that doesn't mean you *should*. A second pair of hands, if it can be arranged, would be very helpful. I've replaced a door by myself on the Elantra and it kind of sucked but I did it. The doors on 2-door cars tend to be longer so probably heavier than 4 door cars.
Old 04-03-2014, 06:00 AM
If you have the ability to rent one of these somewhere, do it. You'll be able to swap them by yourself easily.
Old 10-04-2014, 01:55 PM
krazytib's Avatar
Swapping doors is easy. Just have a friend to help you do the job.
