Radiator wiring help needed
Old 02-02-2014, 02:37 PM
bigfishmoney's Avatar
Default Radiator wiring help needed
using a ohmmeter what continuity should i get between the radiator fan wire harness clip and wires in the engine bay? or can they be wired either way?
Old 02-02-2014, 02:40 PM
i need the voltage reading for proper operation as the engine may adjust voltages and cause overheating if its wired backwards.
Thanks
Old 02-02-2014, 04:04 PM
They get 12v constant and receive ground to turn on.
Old 02-03-2014, 03:33 AM
Thank you
Old 02-12-2014, 01:33 PM
my original problem was if the wires are backwards or not guess that does not matter thanks jongtr...
Old 08-20-2014, 11:45 AM
Does this mean that it does not matter which way the wires are spliced back together?
Old 08-30-2014, 05:39 PM
fixed
