Any way to add LED's to the cup holder?
Vehicle: 00 elantra
2000 Elantra's have the same cup holders has RD1 and 2 Tibs (the pop out style from the dash). Is there any way to add LED's to it so they light up blue when you pop them out to put a cup in them?
I'm sure you could wire in a trigger switch, perhaps a push button one that is "on" when its depressed and "off" when its pressed, then drill and mount on the side of the cupholder box. That way when the tray is opened up the switch is released, turning "on" the LEDs. Everytime its closed, it presses the switch turning "off" the LEDs. then a small LED strip on the underside of the plastic tray should be sufficient.
Also be careful when you take apart the cup holder mechanism the metal coil spring is kinda sharp.
I'm going by memory of what the Cup holder looks like, because I'm too lazy to walk downstairs and out to the barn to look at it.
