Getz engine Accent. Fuel Lines.
Old May 8, 2013 | 09:19 AM
Antonyr123's Avatar
Vehicle: Hyundai Accent
Default Getz engine Accent. Fuel Lines.
Hey, i have a low mileage getz engine in my accent.
The Accent had a fuel return rail.
The getz as normal Single feed.
Can i just block up the Return on the accent ?
If i leave it open the fuel will just evaporate ?
Old May 8, 2013 | 05:20 PM
If you leave a fuel line open . . . the car might turn into one big carbon footprint. If you are converting the engine to a non-return fuel system, at least block off the return line!
(unless somebody else knows better. That's just right off the top of my head where I remember being on fire one time with gasoline as the fuel so... )
Old May 8, 2013 | 11:23 PM
Swap the accent fuel rail over to the getz engine, job done
You realise that the return line actually flows quite a bit of fuel, right?
Old May 10, 2013 | 04:47 PM
Antonyr123's Avatar
over 80% of accent in uk don't use Fuel Returns.
I got rid of my engine about 2 years ago or else i would of swapped it over.
Every single LC 00-03 listed on ebay isn't fuel returned. http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
Something weird is most of fuel rails in that link have 3 mounting points. Mine as only 2.
will a Beta Fuel rail fit accent ?
Old May 11, 2013 | 05:58 AM
No it won't. However an X3 fuel rail ought to fit, and they were definitely all return fuel systems.
Old May 12, 2013 | 02:50 AM
Antonyr123's Avatar
But X3 fuel rail don't bolt to my manifold. They also have no support for the injector harness.
I think im getting mixed up with the vapor return for the vapor canister behide rear bumper.
