TPMS Sensors
Old Apr 14, 2013 | 06:25 PM
wyst's Avatar
Vehicle: 2013 Genesis 3.8
Default TPMS Sensors
Will the TPMS sensors from the stock 18" wheels work in the stock 19's without throwing a TPMS light?
Old Apr 14, 2013 | 06:40 PM
SR Tech's Avatar
Vehicle: 2011 Tuscon
As long as you swap the orginal sensors over (they should fit)) to the 19"s then yes they will work.. If you get a set of wheels that already have sensors in them they will need to be registered to the PCM or the light will be on
Old Apr 15, 2013 | 06:12 AM
Tak82's Avatar
Vehicle: 1997 RD 4-door
most tire service shops have a special scantool specifically for sensors that also plug into the tpms module via obd-II port to reset or test sensors and delete the tpms light.
it's also interesting that late model hyundai's are starting to adopt using rubber valve stem sensors..
