Outter tie rod
Old Apr 14, 2013 | 06:22 PM
dropshifter5's Avatar
Vehicle: 2001 Accent GL
Default Outter tie rod
My outter tie needs to be replaced. Is this something can be changed easily or should I take it to a mechanic? Im comfortable doing my own suspension drop and lowering my car. Would it be about the same difficulty level or easier/worst? I know I would have to take the car to a mechanic regardless for an alignment after its changed.
Old Apr 14, 2013 | 06:52 PM
SR Tech's Avatar
Vehicle: 2011 Tuscon
As long as its not rusted solid, which based on your location you should be fine, you should be able to do it in your driveway with basic hand tools in about 20mins. You just need to try and put the new one back on somewhat close to where it was originally and go get it aligned.
not that hard actually as long as its not rusted to hell I'd say go for it
measure how far the old one went down the threads and reinstall the new one as close as possible, your alignment guy will love you
oh and be prepared to swing a BFH at it
Old Apr 14, 2013 | 08:01 PM
Antonyr123's Avatar
Vehicle: Hyundai Accent
what i recommend u do if its tight. I sand the flat edges then use a adjustable wrench. I think England is wettest country in world lol So i know about hard bolts.
Old Apr 15, 2013 | 06:17 AM
Tak82's Avatar
Vehicle: 1997 RD 4-door
you can either use a pickle fork and wedge it open with a hammer, it will kill the boot but you're replacing it anyways, or you can take a lead or mechanic's grade hammer "no nail hammer" and whack the sh*t out of the tapered knuckle..if you have a torch..it will help also since it relieves the surface tension.
