Changing spark plugs
Old Apr 2, 2013 | 04:49 PM
Lime Rock Turbo's Avatar
Vehicle: 2010 Genesis 2.0
Default Changing spark plugs
How hard is it changing the plugs on a 2.0? My car is 3 years old now and the plugs have never been changed. Thinking its probably a good idea to do it soon. What are the best plugs to use for this car?
Old Apr 2, 2013 | 06:21 PM
Antonyr123's Avatar
Vehicle: Hyundai Accent
NGK are most oem branded hyundai plugs
2010-2012 2.0 Hyundai Genesis coupe Turbo
Info on part number are from here
http://www.jscspeed.com/catalog/NGK_...pe-8353-1.html
Cheaper: NGK Iridium IX Part Number 6619
(http://www.ebay.com/itm/4-PCS-NGK-IR...af9f6d&vxp=mtr)
Expensive: NGK Laser Iridium Part Number 6481
(http://www.ebay.com/itm/JDM-NGK-ILFR...1715b9&vxp=mtr)
Hope this Helps you.
Old Apr 3, 2013 | 12:33 AM
I'd also recommend changing your plugs more often than that. Have you kept all the other servicing up to date?
Old Apr 3, 2013 | 04:20 PM
Red Raspberry's Avatar
It's easy to change them. You need a long extension though.
OEM are Denso and are the best. If you get the NGKs the get the Laser Iridium Part Number 6481as it is comparable to the OEM Denso. Set gap at .032"
Old Apr 3, 2013 | 05:45 PM
^ Set gap at .032" ??? I thought HMC recommends gap to be between .39 - .42 I thought most GC owners generally set their gaps at .40
Old Apr 3, 2013 | 07:22 PM
That's what works for me. OEM they are around .028. The factory spec will cause blow outs.
Old Apr 4, 2013 | 01:30 PM
If you're boosted maybe. I've always gapped mine at 1mm (0.040") with no troubles.
Old Apr 4, 2013 | 07:21 PM
Hyundai service def says .39-.42 gap
Old Apr 4, 2013 | 08:40 PM
I know what the manual says. They come out from the factory at .028.
