bigger injectors what should I get
Old Jan 30, 2013 | 12:03 PM
MINKISS's Avatar
Vehicle: 02/Hyundai/Elantra GLS
Default bigger injectors what should I get
As I now have my 02 elantra boosted I'm looking for bigger injectors and was wondering what I should get I read on a couple other sites of ppl using injectors off an accent but was wondering if someone had a good recommendation on injector or even how to do my fuel system. The car is also not tuned yet but I want to get eveything before I tune it i also will be getting a gmail 3 bar map sensor
Old Jan 30, 2013 | 12:10 PM
you need a way to tune the vehicle before you even think of getting a 3 bar and larger injectors
Juanra's Avatar
How do you control your injectors?
Old Jan 30, 2013 | 03:21 PM
MINKISS's Avatar
I don't at the current moment like I.said I just got the turbo on and done wanna drive it to much especially without a tune
Old Jan 30, 2013 | 09:41 PM
It's not done. It's only half begun. Don't drive it until the turbo is off, then get a proper engine management system installed and half-tuned, then drive onto the trailer to get to the local dyno shop where it is properly tuned.
Unless you just really relish the prospect of replacing the or engine AND getting a tune.
Old Jan 31, 2013 | 03:22 PM
yellow01's Avatar
Vehicle: 01 tib t3t4
AEM fic has built in map sensor which will solve two of your immediate needs. prob need fuel pump, and injector size will depend upon horsepower goal. Dont drive until tuned
Old Feb 1, 2013 | 03:20 AM
XGODZX's Avatar
As the guys said above engine management and tune ,3 bar is about 43 psi I'd doubt you'll get that far.
Bosch 945 30lb RED Top Fuel Injectors & Walbro GSS-342 In-Tank 255-Lh Fuel Pump.
