Beta Swapped Accent Engine Clearance
Old Jan 12, 2013 | 05:33 PM
Default Beta Swapped Accent Engine Clearance
For those times when some noobie wants to know how much clearance there is around the engine after an Accent gets a Beta engine installed, I ask those of you with swaps post up pictures of your engine bay, and especially the water pump pulley-to inner fender clearance.
wheel_of_steel provides the first image. His LC Accent has an alpha transmission, three slotted mounts, and stock axles . . . and enough room to slip a credit card between the pulley and the fender.
Old Jan 13, 2013 | 01:47 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
I will try and get a pic up later but I have more room then that, basically enough to literally squeeze belts on and off.
Old Jan 29, 2013 | 01:47 AM
98x3beta's Avatar
Vehicle: 1998/Hyundai/accent
Where can i get a solid mount like that from?
Old Jan 29, 2013 | 11:03 AM
HotBlue02's Avatar
you have to make it, i did mine using the Accent's mount and a new piece of square stock drilled to the beta config.
Old Feb 12, 2013 | 10:56 PM
98x3beta's Avatar
Sick. I like that alot!! I will deffenetly do somthing like that!!
Old Feb 12, 2013 | 10:57 PM
98x3beta's Avatar
