Remove Carbon from Exhaust Tip
Old May 17, 2012 | 09:47 AM
cysco00's Avatar
Vehicle: 2012 Veloster
Default Remove Carbon from Exhaust Tip
Just curious if there are any recommended cleaners to use to easily remove carbon build up on the exhaust tips?
Old May 17, 2012 | 11:36 AM
That would be a losing battle mate. Perhaps try a brake cleaner or something, but it will blacken up again within 20 miles of driving?
Old May 17, 2012 | 10:50 PM
Cars make soot, and it deposits in the tailpipe. A little. All of them. This may get a little less-bad after the engine is fully worn in, but unless you have chunks of build-up back there do NOT worry about it. There are a few products you can apply to the tips that will let the carbon wipe right off with a damp cloth. I wouldn't know what they are because I have cleaned my exhaust approximately* zero times to remove carbon build up.
*Maybe once or twice when it was new?
Old May 19, 2012 | 07:01 PM
krazytib's Avatar
I usually clean the outside of my exhaust tip every time I wash the windows on my car.
Old May 20, 2012 | 05:40 PM
I have to lightly sand the rust off my MS exhaust tip every now and then. It's a hard knock life.
Old May 23, 2012 | 06:18 PM
Neziah's Avatar
Vehicle: 2012 / Veloster
I just use car wash soap and an old mitt to clean it when I wash my car. shines up fine each time so far.
Old May 23, 2012 | 06:33 PM
Using the same mitt or sponge on the body that you use on the rims or exhaust will cause micro abrasions and scratches in the clear coat. You should always use the cleanest, newest, best condition possible of sponges or mitts on the paint.
Old May 24, 2012 | 12:45 PM
Red Raspberry's Avatar
If it's metal I use a plastic scrub pad and mineral spirits.
Old May 24, 2012 | 09:57 PM
Neziah's Avatar
I use an "Old" one for the exhaust, not the same one as I use on the paint.
Old May 24, 2012 | 11:51 PM
Errm, aren't all exhaust tips metal? Unless you have some crazy bosuzoko angled glass pack.
