tubing size matter?
Old Mar 19, 2012 | 12:16 PM
Bart's Avatar
Vehicle: 2000 Tiburon
Default tubing size matter?
Hi I am thinking about setting up with hard lines. I work in a plant where we use tubing to feed all our instrumentation and controllers. We use 1/4 and 1/2 inch tubing. I see that the normal nitrous tubing sizes are generally 1/8 and 3/16. Can I go with 1/4 inch lines on my setup and what troubles could I run into?
Old Mar 20, 2012 | 08:21 PM
I'm guessing it would only lead to slower fill times when the valve is open, and greater waste when the system is purged. Not so much you'd notice, but if you ran calculations. I can't think of any other reasons besides cost why you wouldn't use larger lines.
Old Mar 30, 2012 | 03:13 PM
zero_gravity's Avatar
Vehicle: 2004 Hyundai Accent
depends on the pressure and flowrate required. as stocker suggested, i doubt it matters much. you are going to reduce the pressure a bit, but the way i see it try it and see if you are happy with the results. if not, you can always switch out the tubing later.
