Performance Front Sway Bar 2004 Accent
Old Mar 16, 2012 | 08:39 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
Default Performance Front Sway Bar 2004 Accent
Looking for a performance front sway bar that will fit my 2004 Hyundai Accent. I re-call hearing White Line made one at one point???? (but is now discontinued) Maybe you have one in your garage from a old build your not using? Maybe you have one on your car now that you would be willing to part with? I know it's a long shot, but figured I'd give it a try.
Thanks, Paul
Old Apr 5, 2012 | 08:16 PM
'treezy's Avatar
I have one from a 1997 tib. Not sure if it's any beefier or compatible??
Old Apr 5, 2012 | 09:37 PM
pas1216's Avatar
I'm pretty sure that it wouldn't fit. Tibs are quite different than Accent's. Thanks anyway.
Old Apr 6, 2012 | 03:54 AM
Hmmm, how about one from an X3? A member on my local forum is selling his (23mm iirc) X3 front swaybar. It'd just take an afternoon at the junk yard seeing if they swap.
Old Apr 11, 2012 | 11:05 AM
Nothing to compare with, no stock front sway bar.
It's unnecessary on an Accent, that's why they're as common as unicorns with light sabers.
Rear sway is all you need. A front sway will increase the car's tendency to understeer.
Old Apr 25, 2012 | 10:18 AM
pas1216's Avatar
Thanks for the good info, sorry I missed your post.
If someone still has one they want to part with I'll buy it, but no hurry.
