2002 gsi 2.0L swap
Old Mar 11, 2012 | 09:24 AM
hyundai2002's Avatar
Vehicle: 2002 Accent GSI
Default 2002 gsi 2.0L swap
I have a 2002 accent gsi 1.6L DOHC. I bought a 2.0L from a 2002 elantra. The wiring scares me a little bit. I've matched up all the plugs and there the same. The only different one was the crank sensor (which I have). And I know your supose to use the 1.6 coilpacks. All the other plugs camshaft sensor, tps sensor etc are all the same. Is there something I'm missing? I'm continuing to use a MAP base because both engines have. Someone help.
Old Mar 11, 2012 | 09:27 AM
pas1216's Avatar
Vehicle: 1991 Impulse RS
all of your answer can be found using the search function. This swap has been done MANY time before.
Old Mar 11, 2012 | 09:34 AM
Well then I would assume it would be pretty easy for someone to tell me if the wiring Is
As easy as I think it is. Don't really have time to read through five hundred threads.
Old Mar 11, 2012 | 03:00 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
Yes, use your 1.6L harness and repin it at the ecm plug if you are gunna use the 2.0 ECM. My 1.5L 2002 accent was swapped with a 2002 elantra so ive been down this road.
My link
Also here is a swap walkthrough for engine install
My link
If your gunna run the 1.6L ECM you are loosing out on the full potential of the engine power, after all the ecm is tuned to run the 1.6L, not a 2.0. If you are gunna use the 1.6L ECM follow this swap
My link
All of these can be found as stickied post's in the Hybrid Section. Any other questions feel free to ask.
Old Mar 11, 2012 | 03:11 PM
HotBlue02's Avatar
This is a myth, you can use the Beta coil packs, The plugs just have to be repined, very easy.
The Idle Speed Actuator needs to be repined to be correct, yes the plug is the same but 2 wires need swapped around. Im looking at schematics right now helping out another Beta swapper, looking at the Beta 1 Pin out you need to swap pin 1 and 3 at that plug. I know, you have a Beta 2, same deal. Other then repining your coil plugs I believe that these are the only plugs under the hood that need repined to the proper order.
Old Mar 12, 2012 | 04:50 PM
My link
My link
My link
Thanks a lot for the help man, I appreciate it. So I'm probably just going to use the 1.6L ecu for now.
What needs to be changed if I do that? What I'm going to do is drop the engine in and level it, then weld
The Mount. Blocking everything of course.
Old Mar 12, 2012 | 04:53 PM
So after changing those wires up, will it run? And same on the coil packs you use the 1.6l ones and just swap
The wires on each one?
Old Mar 12, 2012 | 04:55 PM
Sorry about that, that's just what I heard. So I can just use the 2.0L coil packs and just swap the wires on each?
Old Mar 12, 2012 | 05:35 PM
pas1216's Avatar
READ the links. All of your answers are there. Hotblue did all the searching, now it's your turn to read.
Old Mar 12, 2012 | 09:42 PM
hyundai2002, you are finding one of the 'features' of hyundaiaftermarket.com: all of the information is here. Sometimes we will even give you links if we're feeling generous. But people start to get personally offended when, having done all the work and gone to the trouble to write it up and answer all the questions, you don't want to read what they wrote.
Read, think, read again, then come back with a specific intelligent question and the people who have done it before will be happy to help. If you refuse to go to some trouble to read what they/we have written, you will probably start getting flamed.
