McGyver Tools
Old Feb 22, 2012 | 12:48 PM
Lone Accent's Avatar
Vehicle: 2001 Accent
Default McGyver Tools
Anybody ever made their own tool(s) to use on stuff? The most I ever did was make my own breaker bar and that’s it.
Old Feb 22, 2012 | 01:03 PM
I may have built a lock breaker in case I got locked into a wilderness road.
Old Feb 22, 2012 | 03:14 PM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
used a penny instead of a flathead screwdriver-...
Old Feb 22, 2012 | 06:37 PM
krazytib's Avatar
Welded a wrench a to a deep socket instead of buying the tool needed to adjust the valves on my old prelude.
Old Feb 22, 2012 | 06:42 PM
red97tib's Avatar
Vehicle: 1997/Hyundai/Tiburon
Made a 13.5mm wrench with a grinder and a 13mm wrench. With a welder a grinder and Craftsmen tools you can make neat stuff and then try to get new ones. Or cheap Kmart tools that you don't mind destroying.
Old Feb 22, 2012 | 07:22 PM
Red Raspberry's Avatar
Worked with a guy who had a channel lock, screwdriver, crescent wrench all welded together as one.
Old Feb 22, 2012 | 07:27 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
^^^ Was his name Jacob Two Two?
Old Feb 22, 2012 | 07:28 PM
That was a post that got lost in space and went through a worm hole to return as two.
Old Feb 22, 2012 | 08:39 PM
I've welded sockets to lock nuts before, that was just out of necessity though.
I may or may not have done soldering with a bic lighter
