Tuning software
Old Feb 3, 2012 | 09:06 PM
DTR's Avatar
DTR
Vehicle: 01 Tiburon
Default Tuning software
what are you guys useing for tuning software for the MEGASQUIRT......and does any one have a few base maps for runing 10psi 15psi..thanks...
Old Feb 4, 2012 | 01:17 AM
300D50's Avatar
The B&G official software is the "best", hands down.
I'd use megatunix myself, since I run linux. But that's just me.
Old Feb 5, 2012 | 07:16 AM
jack's Avatar
Vehicle: 97 tiburon
I use tuner studio, it's very user friendly. If you do go with tuner studio pay for the full version. I'm running MS3 on my supra so the maps I have won't help. not sure if you've seen this quick start link, I found it very helpful.
http://www.msextra.com/doc/ms3/quickstart.html
Old Feb 6, 2012 | 09:58 AM
slow 2K2GT's Avatar
Vehicle: 2003 Hyundai Tiburon i4
I use the paid version of Tunerstudio as well and it is well worth the money. The developer is constantly upgrading and improving the software, hes even in the works of making Android software at the moment. I have a MSII tune that I have been using at 11psi and can send you screen shots of my VE tables however will not send out the actual tune.
Old Feb 7, 2012 | 09:23 PM
koreancorvette01's Avatar
Vehicle: 2001 Hyundai Tiburon Turbo
I use Megatune and Tunerstudio full version. I have alink to my screen shots and maps in my sig. Good luck let us know if you need any help. Get ahold of Megalog viewer also it will adjust your VE map off of your log files and compare your ideal AFR verses actuall and change the VE cells for you. Makes tuning very easy to do.
Old Feb 8, 2012 | 11:42 AM
DTR's Avatar
DTR
Vehicle: 01 Tiburon
Thanks guys
Old Feb 21, 2012 | 12:26 AM
DTR's Avatar
DTR
Vehicle: 01 Tiburon
the 650cc Injector what kind of psi and HP are they good for thanks
Old Feb 21, 2012 | 07:32 AM
Red Raspberry's Avatar
Here's a link that you can use to figure out the FI numbers.
http://www.rceng.com/technical.aspx
Old Feb 21, 2012 | 10:30 PM
DTR's Avatar
DTR
Vehicle: 01 Tiburon
can someone tell me if these fit a 2001 tiburon need to know asap thanks
http://www.ebay.com/itm/270718261308...#ht_929wt_1037
or http://www.ebay.com/itm/150759559862...#ht_632wt_1270
i think both will but need a lil help so i dont f it up
Old Feb 22, 2012 | 08:03 AM
03tibe85's Avatar
Vehicle: 2003/Hyundai/Tiburon
They will physically fit in the rail and manifold but they are shorter than than your stockers. You would need to do some modifying of your stock fuel rail to get them to work.
