Thoughts on a SS clutch line
Old Feb 2, 2012 | 01:44 PM
travis's Avatar
Vehicle: 2001 Tiburon
Default Thoughts on a SS clutch line
I upgraded my brake lines to SS and didn’t see any noticeable changes in braking. Would there be a different with the clutch if I upgraded to an SS line?
Old Feb 2, 2012 | 02:02 PM
300D50's Avatar
Reliability is about it, slightly more rigid pedal.
You can make one for the same price as an oem using Jegs line and fitting ends if you want to.
Old Feb 2, 2012 | 07:35 PM
segagen's Avatar
Vehicle: 2010 Genesis Coupe 3.8 - 1999 Hyundai Accent Hatch
What he said ^
I have one and didn't notice too much of a difference if any at all. It was cheap though and I was going under their anyways so figured why the hell not.
