Subwoofer emmitting high pitch humming
Old Jan 10, 2012 | 11:19 AM
Kent's Avatar
Vehicle: 2007 Santa Fe
Default Subwoofer emmitting high pitch humming
I've just finished installing a 10 in sub in my Santa Fe. I've got all wires wired correctly (Triple checked), with 8 ga wires for power and ground. as soon as i turn on the car and the deck turns on, the humming comes on. Bass and everything sounds good, but high pitch humming is annoying the crap outta me.
Old Jan 10, 2012 | 11:22 AM
check RCAs. The connectors on my RCAs were loose from the wires being pull to the side and it caused humming.
Old Jan 10, 2012 | 02:40 PM
Also check that you're properly grounded to solid metal.
Old Jan 10, 2012 | 04:36 PM
holeshot69's Avatar
Vehicle: 1998 Tiburon
Worse when you increase rpm?
Old Jan 11, 2012 | 10:08 PM
bdiggy's Avatar
Yeah, you could be getting engine noise. Does it hum when the car is turned to acc, or just when it's running?
